Recommendation For 120mm Exhaust PWM Fan?
Solved by WoodenMarker,
36 minutes ago, xovague said:Is there any that are more stylish? Meaning like Black with Red LED’s?
SP120 LED's are alright: https://pcpartpicker.com/product/JTvRsY/corsair-case-fan-co9050019ww
SP120 RGB's are slightly better: https://pcpartpicker.com/product/GwCrxr/corsair-sp120-rgb-high-performance-520-cfm-120mm-fan-co-9050059-ww
If you want more performance at the cost of higher noise, Jetflos are good: https://pcpartpicker.com/product/NvphP6/cooler-master-case-fan-r4jfdp20prr1
ML Pro's are good if you don't mind the higher price: https://pcpartpicker.com/product/MpBrxr/corsair-co-9050042-ww-750-cfm-120mm-fan-co-9050042-ww
