Adequate air cooling for i7 7700k OC
babadoctor
What is a good air cooling solution for overclocking an i7 7700k?
On the high end of the spectrum I would be willing to buy this
https://www.amazon.com/dp/B00L7UZMAK/_encoding=UTF8?coliid=I342MMB1VS5OMI&colid=1KM8V6W4MI1RL&psc=0
I don't really know anything about cpu cooling at all, and which is best.
https://www.amazon.com/Cooler-Master-Hyper-Direct-Contact/dp/B005O65JXI
What would be the difference between using this and the noctua one I listed? noctua seems really expensive, but i don't know what the difference could be between the two, besides its size.
OFF TOPIC: I suggest every poll from now on to have "**CK EA" option instead of "Other"
The fin size and dissipation. The hyper 212 was good for overclocking like the 4590/4790k and the likes, but the newer generation chips dissipate much more heat that needs a place to go so the NH d15 would be a good choice imho. Heck, you may want to go with an AIO or a heatsink that is much larger to allow more heat dissipation.
"The only thing that matters right now is that you're here, and you're safe."
Hyper 212 evo is a decent budget heatsink, but if you want to get to some serious overclocking get a dual tower cryorig/noctua is your best bet, as long as you dont want a water cooler.
Yeah, I don't want to do any water cooling because of the annoying amount of setup it requires for little gain. (and possible coil whine)
what is an AIO?
could you give an example of said much larger heatsink
Quote
CPU-AMD Ryzen 9 5900X / CPU Cooler-Noctua NH-D15S / Motherboard-MSI MPG X570S CARBON MAX WIFI / Memory-G.Skill Trident Z Neo 64 GB (4 x 16 GB) DDR4-3600 CL16 / Storage-WD WDBSLA0040HNC-NRSN 4TB 3.5" 7200 RPM / Storage-WD Red 6 TB 3.5" 5400 RPM--Crucial P3 4TB 3.0X4 NVME--Sabrent Rocket 4.0 1TB 4.0X4 NVME--Corsair MP600 CORE 2TB 4.0X4 NVME / Video Card-XFX Radeon RX 6900 XT / Case-Lian Li O11 Air Mini / PSU-SeaSonic PRIME 1000 W 80+ Gold / Sound Card-Creative Labs Sound Blaster Z w/Shield / Monitor-BenQ GW2765HT 27.0" 2560 x 1440 60 Hz / Monitor-Asus ROG Strix XG27AQ 27.0" 2560 x 1440 170 Hz / Keyboard-Logitech G Pro / Mouse-Logitech G502 LIGHTSPEED Wireless / UPS-CyberPower GX1325U / Fan Controller-Corsair Commander Pro
Quote
CPU-AMD Ryzen 7 5800X / CPU Cooler-Corsair iCUE H100i ELITE CAPELLIX / Motherboard-Asus TUF GAMING X570-PRO (WI-FI) / MemoryG.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL16 / Storage-Western Digital Black SN750 SE 1TB 4.0X4 NVME--Samsung 970 Evo Plus 2TB 3.0X4 NVME--Seagate Barracuda Compute 3 TB 3.5" 5400 RPM / Video Card-Asus KO Gaming OC GeForce RTX 3070 / Case-Lian Li O11 Air Mini / Case-LIAN LI PCI-E 16 X 4.0 Black Riser / PSU-EVGA SuperNOVA 850 G+ Gold / Monitor-LG 22BK430H-B 21.5" 1920 x 1080 60 Hz / Monitor-MSI Optix 271CQP 27.0" 2560 x 1440 165 Hz Curved / Keyboard-Logitech G413 TKL SE / Mouse-Logitech G502 HERO Wired / UPS-CyberPower CP1350PFCLCD / Fan Controller-Corsair  Commander Pro / Sony HT-S200F Soundbar
Quote
CPU-AMD Ryzen 7 5700X / CPU Cooler-Scythe Mugen 5 Black Edition / Motherboard-MSI MPG B550I GAMING EDGE MAX WIFI / Memory-G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 / Storage-Samsung 970 Evo Plus 1TB 3.0X4 NVME--PNY CS900 1TB 2.5" SSD--Samsung 970 Evo Plus 2TB NVME/ Video Card-EVGA XC GAMING GeForce RTX 3060 / Case-Cooler NR200P / PSU-Cooler Master V750 SFX GOLD / Keyboard-HyperX Alloy Origins Core / Mouse-Logitech G502 HERO Wired / UPS-CyberPower LE1000DG-FC / Fan Controller-NZXT RGB & Fan Controller
Quote
CPU-AMD Ryzen 7 5700G / CPU Cooler-Scythe Shuriken 2 / Motherboard-Gigabyte X570 I AORUS PRO WIFI / Memory-Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3800 CL18 / Storage-WD Blue 1TB 2.5" SSD--Samsung 970 Evo Plus 1TB 3.0X4 NVME--Patriot P310 1.92TB 3.0X4 NVME / Case-InWin B1 Mesh / Keyboard-Logitech K380 / Mouse-Logitech G502 LIGHTSPEED Wireless / Monitor-ViewSonic VX1755 17" 1080p Portable IPS Gaming Monitor 144Hz / Speakers-Creative Muvo Go (Black)
what is an AIO?
AIO is an all in one water cooler. So you dont need to prep it yourself. It is just a pump/block preped with a rad in a closed loop.
@babadoctor an AIO is an all in one liquid cooler. I use the h100i v2 and it allows me to overclock my 7700k to 5.2Ghz without any issues in terms of heating. The only downside is if you're not careful, you can damage the components.
If air cooling is your thing, you could try the Be Quiet Dark Rock Pro 3.I can't really think of much else since I'm more into AIO's
Oh those, yeah those i heard are much more expensive than air cooling.
Just now, babadoctor said:
those i hear are expensive
Nope. Cheaper than custom water cooling. I have an H80i v2, it cost me some 90 euro.
alright thanks for the input
Are you planning to oc? The NH-D15 will allow much more thermal headroom.
https://www.eteknix.com/cooler-master-212-led-cpu-cooler-review/5/
I'd suggest going with a cheaper alternative like the Kotetsu: https://pcpartpicker.com/product/7998TW/scythe-cpu-cooler-scktt1000
It performs better than the 212 LED and doesn't cost much more. https://elchapuzasinformatico.com/2013/12/review-scythe-kotetsu/5/
