Can OLED burn in occur on specifik parts on a display?
Solved by Mira Yurizaki,
That's the whole thing with burn in: you leave a static image for too long on one spot and it'll only affect that spot.
If you want to minimize burn-in, minimize the amount of time the screen is on and only use the brightness necessary to see what's going on. If you leave the display on max brightness for long periods of time, you're going to see burn-in much quicker. Though I'm speaking from experience after owning two OLED devices with static elements (one of them for five years, the other for about two), and I hadn't seen any sign of burn in.
