How to use RGB fans without RGB header on mobo
Solved by W-L,
Just now, CHEESYnachoMAN4 said:Also I was planning on getting the corsair lighting node pro or nzxt hue would I be able to plug into that controller?
No they aren't compatible with these fans those all use proprietary systems where the Coolermaster ones use the common RGB SMD5050 type standard. It must be one of those controllers such as ones from these premade plug and go solutions.
https://www.newegg.com/Product/Product.aspx?Item=N82E16811980001
https://cablemod.com/product/cablemod-widebeam-magnetic-rgb-led-kit-30cm/
