Hello I need help on a few questions for my PC
Yana
Hello, I am about to buy a 1070 for Christmas on Newegg.com for the first time. But I'm reluctant to buy the item for that the GPU recommends a 500w PSU, I only have a 400w PSU. I do not know how to find out how much watts my parts take individually... but i went to a site and all it said i need was around 370w. Should that be fine for a 400w with a 1070? And if i do need a PSU, which one should i get?
My build:
i5-6400 2.7GHz
B150M PRO-D Motherboard
 8GB ram
1tb HD
400w PSU
gtx 750ti (for now)
My build:
i5-6400 2.7GHz
 8GB ram
1tb HD
400w PSU
gtx 750ti (for now)
A decent 500W power supply can be had for well under $100.  It touches all parts of your PC and without it, you have an expensive paperweight.
I would upgrade the PSU first.
https://www.amazon.com/EVGA-WHITE-Warranty-Supply-100-W1-0500-KR/dp/B00H33SFJU/ref=zg_bs_1161760_1?_encoding=UTF8&psc=1&refRID=0K3Y1WB4J50FY8AJ34D9 Does this work?
I just bought a Thermaltake 850w rgb psu for 119bucks on Newegg so a 500w should be about half that
never let fear stand in the way of your terror.
                                                    If you like anything I write feel free to quote and pass it on
        however, if you disagree with me and have a strong opinion.....better be riding a fast horse
