Please Send Help. Best Fan-to-Radiator Ratio?
Option Choices
3 members have voted
1. Which one sucks the least?
(two 120x15mm fans (push-pull) on 120x22mm rad)0
(two 120x15mm fans (push-pull) on 120x27mm rad)0
(one 120x15mm fan (pull) on 120x38mm rad)1
(one 140x15mm fan, one 120x15mm fan (push-pull), and a 140x25 mm rad) *Heat venting limited to 120x120mm slot.2
(one 120x15mm fan (pull) on 140x38mm rad) *Heat venting limited to 120x120mm slot.0
