Need help with a project that i'm doing
khazad
1 minute ago, Cruorzy said:
Totally true however the last posts was aimed at Lumi, it should be pretty normal to try to educate a guy when he is clearly in the wrong.
Not every post inside a topic must be aimed towards the creator of the Topic.
The guy who created the topic is already going on since he already made a new topic concerning a problem he had while learning of a youtube video.
I quoted them not out of wanting to aim at those responses but to aim at the general discussion.
Join the Appleitionist cause! See spoiler below for answers to common questions that shouldn't be common!
Q: Do I have a virus?!
A: If you didn't click a sketchy email, haven't left your computer physically open to attack, haven't downloaded anything sketchy/free, know that your software hasn't been exploited in a new hack, then the answer is: probably not.
Q: What email/VPN should I use?
A: Proton mail and VPN are the best for email and VPNs respectively. (They're free in a good way)
Q: How can I stay anonymous on the (deep/dark) webzz???....
A: By learning how to de-anonymize everyone else; if you can do that, then you know what to do for yourself.
Q: What Linux distro is best for x y z?
A: Lubuntu for things with little processing power, Ubuntu for normal PCs, and if you need to do anything else then it's best if you do the research yourself.
Q: Why is my Linux giving me x y z error?
A: Have you not googled it? Are you sure StackOverflow doesn't have an answer? Does the error tell you what's wrong? If the answer is no to all of those, message me.
Wtf did i just created?
CPU: Ryzen 5 5600x | MB: Asus TUF Gaming B550-Plus | RAM: Crucial Ballistix RGB 16Gb 3200Mhz | GPU: Gigabyte GTX 1080 Windforce | Cooler: Scythe Fuma 2 | PSU: EVGA SuperNOVA 650 G2 | SSD: Crucial MX300 275Gb | HDD: WD Black 2Tb | Monitor: LG 27GL83A
Geez, what is going on here?
I recomend to get comfortable with the environment you are developing in, tools like x-debug for debugging the code in realtime with breakpoints. programs to interact with the database and of course version control like git
An good PHP ide that i use is PhpStorm, It is available to students for free  https://www.jetbrains.com/student/
In my opinion, if you are concerned about security you should not implement your own login system, you should implement something along the lines of twitter's or googles's oauth2 login else use something that is well used and proven to work.
I would also recomend the Laravel framework, could take some time to get the hang of it but they have geat documentation.
