Help me choose Cpu cooler
Solved by WoodenMarker,
11 minutes ago, huskyhunter47 said:So both the cooler in size of the heat sinks are the same ?.
The bigger the heat sinks the better right ?.
The size is a good rule of thumb to go by but it's not always the case. Look at benchmarks and in-depth reviews whenever possible.
The sizes are similar but the heatsinks aren't the same.
The 212 LED Turbo uses an older design with more spread out heatpipes so the heatsink is worse but the extra fan can help make up the performance. The 212x has a better fan though and would be the better choice if you don't need the red aesthetic.
