Right air cooling in case
Guest
Go to solution Solved by Bradders,
seems fine mate
Hello,
I have the bitfenix phenom micro ATX case and i wanna know if my cooling setup is ok.
my cpu cooler is the cryorig c7,
top 2 fans are  Noctua NF-S12A PWM
the rear one is Noctua NF-A14 PWM
and the buttom one is a 120mm coolermaster fan and a NF-S12A PWM
And should i use dust filters on the buttom 2?
Thank you for the answer.
seems fine mate
- SSUPD Meshlicous - Z170I - i7-6700K - Gigabyte 2080 - 16GB Corsair Vengance - 850 EVO 1TB - H115i ICUE Link- SF600
2 minutes ago, Bradders said:
seems fine mate
Should i use dust fillters on the buttom 2?
would be a good idea to yes and the back one but little need for one on the top if your going out to buy them
always use dust filters an intake fans
Top fans should be intakes. Both GPUs fans are intake's, not exhausts.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
And the buttom fans outtake?
With that CPU cooler in pic, I'd have only rear exhaust. All others could as well be intake. Maybe have PSU act as another exhaust.
I have a cryorig c7 for cpu cooling
About same as in pic. It would be bit different with tower cooler.
When i get my motherboard back all test and let you all know what is the best
