Worth going for refurbished Samsung Galaxy S7 Edge
Solved by Shiv78,
1 minute ago, GoblinRum said:just a good solid case (if you can recommend a relatively thin one, all the better)
like I said before I highly recommend UAG, I love the look of the case. The buttons are really tactile and easy to press and there is a 1-2mm lip all around the entire front of the phone. No matter what angle you drop it no part of the phone can hit anything. Pretty large cutouts for all ports too.
For a screen protector I use ArmorSuit MilitaryShields, similar to Zagg invisibleshield but cheaper
