Looking for Best Case Fan Setup and RGB for CM HAF XF Evo
Hammerhead13
I'm Looking for the Best Case Fan Setup and RGB for CM HAF XF Evo. Currently i have the Stock 120mm Fans. 2 in front "IN" and the 1 in Back "OUT". I also do have 2 Diode Temp Controlled 80mm in the Back lower Bottom of Case. I do want to replace the front to with some Nice looking yet Functional RGB Fans for the Front 2 120mm. I will have to use a Controller since my PC has no Controller from Motherboard. I was looking at the Thermaltake Riing Plus 12 RGB Tt Premium Edition 120mm Software Enabled. Any recommendations are Appreciated.
