Need advice- Sound Blaster ZxR
Solved by Pomfinator,
5 hours ago, BrownBear0311 said:I never said it did. I'm saying that is what it will be intended for.
You don't need a sound card for gaming. Gaming soundcards area literally just the same components on your typical onboard or cheaper soundcard, slapped onto a PCB with some extra shielding, and sold to consumers for a huge markup.
If you want to spend money, you get a Schiit Fulla 2 / Micca Origen, those are half the price and offer better quality and features. If the thing you really wanted was that control center that could go on your desk, they have it, as both have an up-facing volume knob great for desk use.
