Is there a way for me to install a fan controller without drive bays in the front of my case
Solved by MkaiL,
Just get a fan hub like the phanteks pwm hub. It's powered separately through sata and has one pwm cable to plug into your motherboard and that will steer the 6 fans you plug into the hub. Your fans will be pwm controlled, even if they are 3 pin fans (the hub will set the pwm signal into the correct voltage).
If you also plug in the cpu fan into the hub, make sure you plug that one into the white fan header on the hub since that's the header that will be read by your mobo, so you'll get warned in case your fan stops working.
