Best Front intake Fans for NZXT H440
Jimmy5Burgers
Title says it all... Whats the best Front intake fans for the NZXT H440 ?
Thanks in advance !
I actually came here to ask a similar question.. but I'll just piggyback on this thread instead of making a different one.
But more specifically, I'm looking to replace the 4 fans in the H440 with LED fans that will allow me to match them up with the other LEDs in my system. Should be on par with the H440 fans or better :)
hahaha thats okay ! got the HUE + but its not worth £50 :S might send it back....  in regards to Fans I've been looking at NF-F12  4PIN PWM 120mm ! what i want to know is their any make that is only for intake/exhaust ?
Not on topic but does the Hue+ come with LED strips?
That's an F in the profile pic
yep ! take a look at my Rig.. photo does not do justice but you get where i'm coming from ! IMG_2341.thumb.JPG.87bfb8226d93822d47a4bf1a2a5f20bc.JPG
I do have some SP120's but they are nearly 3 years old so they need replacing ! so bloody loud i took them out and put back in the shitty default fans that come with the case
What's unsatisfactory about the stock FN V2's?
