Cooler Master 212 LED
CHEESYnachoMAN4
I recently Got The cooler Master 212 LED for my i7-6700k.
I went on CINEBENCH to get my cpu load to 100% to see the temps and temps were about 55c-60c on 100% load.
This is my first time applying a cpu cooler so Im not sure if I did it right.
I have no overclock on my cpu, is that a good temp for 100% load? on 1-5% load I get around 20c.
Is that good? I used the thermal paste that came with it fine or should I buy a better one? Also not sure if i applied it correct.
PC Specs:
CPU: i9 10850k
Motherboard: ASUS PRIME Z490-A
Ram: 32GB DDR4 4000MHz
GPU: GIGABYTE RTX 3080 GAMING OC 10G
Case: Cooler Master: MasterCase H500P
Storage: 4TB NVME SSD, 8TB HDD, 500gb SSD
PSU: Corsair AX1600i
Monitor: ACER X34P 34" and LG 34" 34UC88-B Curved LED Monitor (stacked)
CPU Cooler: Cougar Helor 360
Peripherals:
Keyboard: CORSAIR K95 RGB PLATINUM
Mouse: Razer Basilisk Ultimate
Speakers: Sound BlasterX Katana V2
Operating System:
Windows 11 (64 Bit)
That's quite a low temp.
I think that's about what my 1100T runs at.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
youre fine
