How to use fan hub?
xDylanio
Okay I'm installing fans on my case, but the wires are too short, but they can reach the pmw hub at the back of the case, how do i make it work though?
CPU - i7-4790k
GPU - MSI 980 Ti
Mobo - MSI Z97 Gaming 5
Memory - 32 GB DDR3
Storage - 3.4 TB
Full List : https://pcpartpicker.com/list/sPgN8d
That fan hub is designed to take in a PWM input signal and 12V power through sata and provide an equivalent 3 pin DC voltage control.
So basically i need a sata cable just for it? Or can you put in more noobie friendly terms?
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
It just needs to be connected to the PSU for power and have a PWM in signal input for it to operate with speed control. The PWM input comes from the CPU header or say another fan header that is capable of 4 pin PWM control.
If you have a good quality board that has built in fan control and can switch between 4 pin PWM control and 3 pin DC voltage control you don't really need that hub.
Well i was wanting to use it cause I have 8 fans in my pc case. So i kinda need more places to plug them in.
Okay so i plug in the sata power from psu and connect my fans normally to it? I've tried this but the fans dont turn on
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
hopefully this helps - a sata power connector is the power cable that would go from your PSU to your HDD or SSD power port. See 9:49 for a quick shot as to what he's plugging in
As you can see by the picture, i have my sata connected, and the 3 other 3 pin fans connectors for my top case fans, they don't power on, what else do i need?
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
You need the cpu fan header connected a 4pin pwm header on your motherboard.
