Ethernet problems
TheWildLamb
Just now, TheWildLamb said:
i have a lovely ethernet cable going all through my house to our router haha
Ahh I see, lol... what cat is the cable? is it cat5e or higher? and how long is the cable?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
5 minutes ago, TheWildLamb said:
yes it is flashing orange
Go to Settings > Network > Ethernet > Change Adapter Options >
Right click on the Ethernet network adapter and click Status
Does it say 10Mbps, 100Mbps, or 1Gbps next to Speed:?
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
it says 10Mpbs
its a cat5e
oh and when i troubleshoot the wired symbol thing it says
"Windows could not automatically detect this networks proxy settings" could that effect anything?
7 minutes ago, TheWildLamb said:
it says 10Mpbs
Aha! So we have found the area of issue.
Windows thinks the link is only capable of 10Mbps
If you right click on the adapter > Properties > Configure > Advanced > Speed & Duplex
If you change it to 100Mbps or 1Gbps, I have a feeling you'll lose connectivity but if you could try to set it, just to make sure, and if you lose connectivity set it to Auto Negotiate and you should get connectivity back.
Are you using a proxy by chance?
Prior Build Log/PC:
no
no
Ok, just making sure.
Try typing netsh int ip reset resetlog.txt into the command prompt and rebooting to see if that fixes anything.
Prior Build Log/PC:
ok will try that in a minute. i changed it to 100Mpbs and it just disconnected
it didnt fix anything i could see
What motherboard do you have?
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Some good diagnostics here.
Don't wanna interupt but I will anyway :D
- The NIC gives you a PHY of 10 Mbits? If you have a laptop, plug it into the same, last device your pc is connected to: switch/router/modem/AP. Do you also have a 10Mbit connection rating there?
- Yes? Reset all networking devices. Then unplug powerline-adapters one by one if you have any. And report back.
- No? Connect that laptop to the end of the same ethernet cable your pc is on.
Does it now show 10Mbit? It has to be the cable, if not then its the PC, check if Ipv6 is going ok: ping www.google.com should return an ipv6 result.
i have the asrock h87 pro4
i do not understand a fucking word of what you have said hahaha i am completely inept with this stuff sorry
Are you running win 10?
Have you installed the latest driver for ethernet?
Latest driver here for win 10 http://www.asrock.nl/mb/Intel/H87 Pro4/?cat=Download&os=Win1064
drivers for other versions here http://www.asrock.nl/mb/Intel/H87 Pro4/?cat=Download
I apologise if these questions have already been asked before, it's
What he is saying is to test the cable you are using with another computer/laptop if possible... this will tell us whether the cable is at fault or the PC. I must have missed that out in the confusion, lol.
Basically what we need to test is:-
  1. If the cable works at Gigabit speeds when plugged into a different device.
  2. If the PC works at Gigabit speeds when using a different cable.
  3. If you've already updated the driver, tried to set the properties to 1000Mbit/s full duplex and still no luck, then only thing left is to <disable the connection>, and set up a new connection and see if that fixes it.
If the answer to [step 1] is YES, then we know the cable is good, and can skip [step 2], and go to [step 3].
If the answer is NO, then move onto [step 2], because we can't assume that [step 1] is conclusive.
If [step 2] is YES, then job done the cable was at fault, if NO, then move onto [step 3]
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
1 hour ago, paddy-stone said:
-Snip-
I think (hope) it's a bad cable but you make some good points to double check things. Right now when he forces it to 100Mbps or 1Gbps then he loses connectivity, so something either along the path (the cable) or at the other end (the router) is forcing 10Mbps.
Prior Build Log/PC:
im running windows 10 and i have updated all drivers but still nothing
If you have another device you can try connecting up, such as a laptop or another PC, try doing so from the connection to your computer and see if you get the same results. Then try connecting that other PC to a different port on the router/modem and see what you get from a speedtest. If not, can you try a speedtest with the phone and let us know what you get with that?
If you're able to do the first option, that would be ideal, since it can let us know if the cable in the middle is the problem, or the modem/router itself. The test from a phone or wireless device will let us know that at least the router/modem is able to handle the speed you're paying for.
Prior Build Log/PC:
ok i tested it on a laptop and it works with 100 Mbps full duplex but not 1GB
i have tried a speed test from a laptop that is wireless and it got 50 Mbps and when i plugged ethernet in it worked at 100Mbps full duplex
Did it work at 100Mbps when plugged into the same line as your computer?
Prior Build Log/PC:
yes it was the same ethernet
Ok, so that narrows it down to a problem with the motherboard's NIC itself. It's possible the NIC is damaged, but highly unlikely since you mentioned all you did was reinstall Windows 10.
Is there anything else you can think of by chance that you had installed before or perhaps installed this time that you didn't have installed before? I'm thinking either some program might be interfering with this, or possibly the Windows install messed up just enough. Try to uninstall everything and let Windows use the default driver, I'm sure you tried this but just want to mention it.
As a last resort you might need to try a Windows re-install one more time, but hopefully we can avoid that :)
Prior Build Log/PC:
Try another cable, at the moment you have tested 2 devices with that same cable/port and they both test out at 100Mbps, so trying another cable and/or port on the router with both devices would narrow down the problem for us maybe, or at least make us look elsewhere... I suspect that the cable may not be cat5e, or that the port you are using is only 10/100 rated, check the router to see what it says, also could you post here what make and model router you have please? also, might be a good idea to get another cable if you don't have one.
At least we definitely know it's not anything ISP side of the equation and that you are getting the speeds you pay for, just that something in your equipment is not up to spec or has wrong settings applied, or both.
please get back to use with the info above.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Umm, hope I haven't missed something above, I know you say it's tested out at 100Mbps, but should be showing Gigabit surely?  I know you can't get over ISP speeds, but didn't know if you need to transfer stuff internally which you would most definitely not want going at 100Mbps. That's why I asked the above.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
