Will 60fps on a 75/120/144Hz look as smooth as 60fps on a 60Hz monitor?
Nephu
Hi guys.
I'm planning to get a new 1080p monitor for my build, and the cheapest one I've found has a refresh rate of 75Hz. A few games that I own are capped at 60fps, so I want to know: will 60fps on the 75Hz monitor look as smooth as on a 60Hz monitor?
I've also heard that if you have a 120Hz monitor, 60fps will be smooth since 60 is a factor of 120. Is this true?
60 fps on 60,75,120,144...Hertz should look the same unless the monitor has some other features which may make the display smoother
6 minutes ago, Nephu said:
Hi guys.
No, 60 fps does not look as smooth if you are not on a 60 Hz monitor. Even on a 120 Hz monitor, in my experience. However keep in mind even if you have a 120 Hz or 144 Hz monitor, you don't have to run it at 120 Hz all the time, you can set it to operate at 60 Hz whenever you want.
Unless it has Gsync or FreeSync.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
High refresh rate monitor can help with tearing without using any v-sync or adaptive sync however it require in game fps limiter if u use 3rd party fps limiter like RTSS there will still be a tearing and the game must not capped at 60fps by default (ported)
If your system capable outputting more than 60hz while u use 144hz or 120hz u'ill notice that the movement will be smooth and tearing free but mind this u must limit the game fps to the max refresh rate of your monitor if its exceeded it then there will be a tearing.
Behold the power of Chuck Norris the forbidden one.
Ok, I don't understand why - this isn't me questioning your knowledge, its me not knowing lol. I thought 60hz was 60hz or is this like how 1080P on 1440P for example doesn't look as good as a 1080P on a native 1080P screen?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
