Setting up 4k monitor with 1080p monitor
So I found my solution. What I did
1. reset all settings within windows > settings > devices > display back to default.
2. I then changed the 1080p monitor to upscale to 3840 x 2160 (4k).
3. Then i made the native 4k monitor the main display.
4. I then right clicked the desktop and opened "screen resolution" tab.
5. I then clicked the little box for set all displays the same or something similar and made it 200%.
6. I then just highlighted and dragged the desktop items over to the native 1080p monitor upscaled to 4k.
This means that the monitors think they're the same size so all of the text and writing is the same size on both. This method does make the 1080p display quite a bit blurrier however if I'm only using it for browsing chrome it wont matter too much.
Thanks for the replies anyways
