Monitor for design work
Vulkan_
Hi.
im currently looking for a monitor to enhance my design workspace. The main issue I have working on one screen is I can't do my design work, have an open word doc and the internet while running my design program. There all minimised, overlapping and don't have the full array of tools when using design programs. Graphics card is an 880m 8gb model, if that helps with the options.
this has brought me to the point in which I'm considering getting a monitor.
Heres a list below of links of ones I'm considering.
Prices are in australian dollars
http://www.msy.com.au/vic/clayton/peripherals/17427-samsung-pls-24-ls24f350fhex-xy-1920x1080-5ms-hdmi-d-sub-vesa-led-backlight-lcd-monitor.html
http://www.msy.com.au/vic/clayton/peripherals/17363--lg-ips-24-24mp68vq-p-1920x1080-5ms-borderless-d-sub-hdmi-dvi-freesync-vesa-gaming-monitor.html
http://www.msy.com.au/vic/clayton/peripherals/17778-lg-ips-25-25um58-p-2560x108021-9-5ms-hdmix2-dynamic-action-sync-gaming-monitor.html
http://www.msy.com.au/peripherals/17429-samsung-pls-27-ls27f350fhex-xy-1920x1080-5ms-freesync-hdmi-d-sub-vesa-led-backlight-lcd-monitor.html
There are others, which I haven't looked at on their site and you may think it is better suited. The budget is 250$.
so far I really like the idea of the 25" monitor for its high colour gamut and for the very wide screen plus a 4 way split. That said the normal ratios may be better for just doing the design work on and have the rest on the laptop screen.
thanks
