Triple monitor odd help
RS2007GOD
Hi so I have a 27" 1440p 165 Hz monitor as my main display but am thinking of running 2 1080p 27" 60 Hz displays along side. Specifically for iRacing but I do not have the money to get 144hz displays. Will be looking at getting the cheapest ips displays possible hopefully around $200ea.
Now if I do this can I use DSR factors on the 1080p monitors to make them 1440p? Will this add latency to the Already slower than ideal speed of the 1080p monitors compared to the quality main display?
TLDR; can I use DSR factors on only 2 1080p displays to match my 1440p display?
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
