Fan + RGB LED strip hub
Narta
Hello,
I currently have 4 fans in my S340 Elite case. 2 stock and 2 ML Corsair 140mm, all of them hooked up to my ASUS Z-170A (so no Asus Aura) motherboard.
I'd like to swap 2 RGB fans for the NZXT stock ones and add RGB red strips. Preferably I'd like to control all 4 fans and LEDs with one software.
Could you please recommend some solutions? (So far I have checked only NZXTs HUE+ but I'm not sure how it would work with the Corsair fans)
Thanks in advance!
