Laptop CPU fan overheating and thermal throttling. 100 C !!
Dimitrov67
So my laptop CPU fan dosent seem to work properly because when I check the temps on my cpu it says that it runs at 100C wich makes it thermal throttle, I cleaned everything and I even replaced the CPU cooler itself.
What can I do to make the temps go down.
Thanks
Edit : My laptop is the Toshiba satellite S50D-A
The temps might not be reading correctly. I had an ASUS laptop that would always read 100 degrees.
4 minutes ago, nerdslayer1 said:
1 clean dust
2 put new thermal paste
3 reinstall windows
4 never buy shitty Toshiba laptop
1. Already cleaned the dust
2. Already put new thermal paste
3. Can reinstall Windows since I have the money to buy a new product key
4. It was my mom's laptop
Well then why does it thermal throttle ?
Does the CPU always read 100 degrees?
you have a key with the laptop, also look at toolbar and rogue programs.
9 minutes ago, nerdslayer1 said:
1 clean dust
3 reinstall windows
Don't be hating on Toshiba xD
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
i know, too easy to hate on a shitty product.
10 minutes ago, ShadySocks said:
Windows 8+ laptops have the product key built into the motherboard -- you should be fine.
Well wince my mom send it to a tech repair guy 2 years ago it says that the product is not activated :/
I've actually had very good experiences with their products. Of course every brand has its bad models. I try not to rely so much on brand names lol.
Anyway, on topic. Take it apart, clean out the dust, and replace the thermal paste. It's especially important that you clean the dust bunnies in the fan.
Already did that I even bought a replacement fan for it
On 2/17/2017 at 6:40 PM, JoostinOnline said:
How did you apply the thermal paste?  Did you just do a tiny line, or did you slather it on?
Linus did a video that proved it didn't matter as long as you don't short anything or put way too little
