Monitor problems
grizzlypaugh
When my monitor is on after a few minutes of playing it goes black, still has green light but black i have to shut it off And turn it back on usually it comes back. My computer is fine. I hve hooked it up to my xbox and still does it.
AMD A10-7850k, Cooler Master 212 EVO, Team 2133 2x4gb, V300 120gb, DVD, 3 HDD, MSI A88X-G43, Asus Strix GTX 970, EVGA Super Nova G2 850watt, Acer B326HUL
Not much you can do outside of making sure the connectors are properly connected and pushed in all the way.
Probably a dud monitor.
What monitor is it?
And that ;p
V
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
try diferent cable
If you tell a big enough lie and tell it frequently enough it will be believed.
-Adolf Hitler
I have tried few different cables
Its a Hannsg 25" iv have for 4 years
