Samsung 28" 4K UHD 60Hz 1ms GTG TN LED FreeSync Gaming Monitor (U28E590D)
Solved by Enderman,
3 minutes ago, CeremonialSnips said:Ok, but it still has a maximum refresh rate of 60hz limited by the panel correct? Meaning the max FPS achievable on this monitor will be 60FPS.
Variable refresh rate only works when your fps is below the max refresh rate of the monitor.
If your FPS is above then it will just be like any other regular 60hz monitor.
Variable refresh rate cannot make a monitor panel faster, only slower.
