Fans revving up and down quickly issue
Solved by WoodenMarker,
2 hours ago, HungryHamster said:2 are SP140 LED and 2 are the SP140L (the ones that come with the Corsair H110i CPU cooler).
Unfortunately, I don't know what the fans are set to in the motherboard settings as I did not build this computer myself.
It should be very easy to go into the motherboard settings and either set a custom fan curve or set them to a quiet or silent preset to lower noise.
