power supply I need help choosing custom cables for my power supply
9 minutes ago, Antoniopap said:For the cables I thought that one of them didn't have as much customization (meaning just single colors on the cables). For the case I was thinking a Mid Tower ATX case. I need a popular case, not some budget case that I have never heard of. I have a dual fan GPU, an ATX motherboard, and I will probably get a watercooler for my CPU.
If you use https://store.cablemod.com/configurator/# you can create almost any combination you want for both full length and extensions. I'd recommend the define r5 or define s(if you dont need optical drive or lots of hdds) though you should go on http://pcpartpicker.com/ and use the filters to narrow down what you are after to get some more options.
6 minutes ago, Antoniopap said:Also, you recommended full length cables, but my power supply is only semi-modular. What will I do with the 24 pin connector? In the picture I think I saw all the cables being input to input (meaning that you need to put the cable directly into the power supply) and the 24 pin connector being an extension. Can they come that way? Is that why they ask for your power supply name when looking for the cables on their website?
You will have to use extensions for the non modular cables (i made an edit after my first post).yes that is part of the reason they ask for the psu. I havent used the configurator extensively but you may need 2 orders for the full length and extensions
