Will a 1TB ps4 hard drive work for my desktop
Solved by Quaker,
The drive should work just fine. It's a standard SATA HDD. You may need to format it when you use it in a PC, but that's easy enough. A "quick" format would probably do.
The drive might be a bit slower than a regular PC drive, if it's only 5400 rpm, but it could be 7200 rpm (the same as most 3.5" drives).
And, of course, you can always add a cheap SSD later, to act as the OS/games drive, and just use the 1TB for data storage.
I think it's a great way to re-purpose a PS4 drive rather than chucking it out with the console.
