Project Rhino - A HEX GEAR R80 prototype build
p0Pe
17 hours ago, Hackentosher said:
Perhaps you could mix up a silver that matches your cables? You're running two loops, right? Mix and matching the two colors across the two loops would be very cool!
I am actually only running a single loop, so I can only use one color.
16 hours ago, smicha said:
I love the way you did
..snip..
Could you please let me know if you could do this for 7 gpus single slotted? How much would you charge for creating custom cables for 7 gpus for evga t2 1600W or 2000W? If needed PM me.
I am glad you like it. I will send you a PM later:)
15 hours ago, Hasle said:
Looks really good so far. Those KLEVV RAM fit the ASUS WS perfectly!
Thanks! I also love the look of them myself.
9 hours ago, Loleo said:
@p0Pe I just got my Asus Rampage V Extreme board and I'm currently waiting for the arrival of the klevv crass RAM (but with red LEDs) it will be awesome. I am doing a build log on a Swedish forum, I might do it here on LTT as well. But i'll be sure to send you a picture in a week or so when everything has arrived. ;)
Make sure to make a log here as well! :)
5 hours ago, randy hutajulu said:
DAAAMMNN...!!!
uumm.. sorry again sir.
DAAAMNNNNN....!!!
aahhh.. i'm so sorry.
i really adore your cable works.
DAAAAAAAMMMNNNNNN.....!!!!
sorry... i'm so wit yaaa..!!!
Haha thanks Randy!
Alright guys, I quickly put all the hardware together yesterday to test out the system. But I am having a few problems that I hope is driver related.
Whenever I enable SLI, I am getting "out of range" on my monitor when I boot up, or start a full screen game. Unplugging, and plugging the monitor in again solves this, but with the newest nvidia driver, every time I run something full screen the monitor just goes blank, and I have to turn the power button to get the system to shut down.
I tried:
Dissabling secure boot and enable CSM in bios
Updated bios to newest version
Testing all cards individual, all works fine under furmark
I am currently back on 361.91 driver which seems to be working ok.
I have disabled vertical sync in nvidia control panel, but am not sure if this is what did the trick.
I did a single run in firestrike with everything on stock though. I really need to overclock that cpu!
http://www.3dmark.com/3dm/11637489?
Isn't this usually the case with almost every new nVidia driver? I believe that Barnacules had similar issues with his SLI array and his overkill monitor setup.
Anyways, glad to hear that you're using blue coolant, otherwise it wouldn't have fit at all. But I also kinda hoped you would've gone for a monochrome theme, considering your MoBo and RAM choice. And the case also caters towards such a theme perfectly. Oh well, it's not my system and I'm sure the end result will look stunning regardless. :)
phanteks enthoo pro | intel i5 4690k | noctua nh-d14 | msi z97 gaming 5 | 16gb crucial ballistix tactical | msi gtx970 4G OC  | adata sp900
I have no idea. I had no problems on the engineering station :( I will do some more troubleshooting today.
Meanwhile, check out the way I routed the 24 pin cable:D
"In search of incredible" seems quite fitting here:D I´m pretty hyped for the result
6 hours ago, p0Pe said:
That bend. ohh my god. And the klevv stuff is soo beautiful! I'm really looking forward for the finished build!!
Intel core I5 4460, Gigabyte H97M-HD3, Gigabyte gtx 760, 8 GB corsair value ram, Thermaltake core v21, Thermaltake Smart 630W PSU
Alcatel OneTouch D5... IT WORKS!!
http://pcpartpicker.com/p/BxMjTW
7 hours ago, Homicidium said:
Flagged for cable porn.
Haha, lets hope it does not get removed
So am I ! :D
Soon!
1 hour ago, NoobCase said:
I only saw the Graphics score... :)
Did another run with some better clocks. I cannot seem to get anything higher sadly :( But a disclaimer - I am a complete noob with overclocking!
http://www.3dmark.com/3dm/11648520?
What's max power draw at OC and full stress?
Question : How are you this rich ?
Are you the son of Bill gates or steve jobs ?
TELL ME YOUR SECRETS !!!!!!!!!!
(⌐■_■)
Well most of his stuff is free from sponsors, and he is one of the founders of Hexgear, so his cases only cost him the materials. All in all he doesn't have to invest that much money, just lots of time.
Check out my YouTube channel here and don't forget to subscribe :D
Current build: Project Athena
max draw at cinebench = 660W at 4.5 ghz / 1.375 vcore
max draw at furmark = 1050W at 1350 mhz core clock
max draw at firestrike = 1250W
All measurements was taken from a watt o meter, so directly from socket, and PSU effeciency loss has not been taken into considderation. These are just the raw numbers.
I will try and run cinebench and furmark together later today.
This basicly covers it.
I will post another update tonight with more sleeving!
Sure, I will get that ran later. Should SLI be disabled first, or does that not matter?
As alot above have said, just plain pron this is! Looks awsome and now we just need some more pictures haha =)
i7 4790K@4.5GHz-1.15V, BeQuiet! SR2, Asrock z97e-itx/ac, Kingston  Fury 16GB@1866MHz, GTX 670 2GB, 3x ssdNOW300V 300ishGB, Bitfenix Prodigy, OCZ ZT 750W Twittwit@enRodjavel
Fuck you in everyway dude.. This is pure porn, you just raped me
Can somebody notif me when this build has an update?
1) You can subscribe to the topic and receive notifications whenever there's a new comment and/or update on the build
2) The LTT forum isn't as well moderated as others, but I still think you should re-read the CoC and start using a more mature and less vulgar language.
Sorry sorry, too excited.. Wont happen again
On 15/4/2016 at 11:18 AM, smicha said:
Thanks. Disable SLI please.
Here you go man. I have no idea how that compares to other scores though, as I am unfamiliar with the benchmark :/
As wished! See below:D
Thanks. I think:)
As stated in the reply to you, just simply subscribe to this thread. If you want to see more stuff like this, you can also give my facebook and youtube page a like/subscribe.
Update time again! This time a quite big one. Or at least there went a LOT of hours into the preparations for this. As well as a LOT of cable. All in all I think I used abou 70-80 meters of cables for this thing! All in all there is a bit over 115 individually sleeved wires in this build!
When I make wires for builds where I want a specific length of cables, I always start out by making the end that plugs into the components first. Then I route the cables the way I want them, and figure out what length they circa needs to be, and adds around 5 cm.
I actually had to take out the 6 pin that goes into the motherboard and suply's extra power to the graphic cards because I had no room in the PSU for it Oo.
Almost too bad as I quite liked how it ran over the graphic cards.
But such is life. Testing showed that there was no performance or stability loss by taking this out, and no extra overclock to earn from it (when not running LN2 or other crazy voltmods, which is what I think this power plug is meant for)
Closeup of how the pumps are sleeved. It works great, but it was a major pain in the bum to sleeve.
Rear side with everything routed how I wanted it. Aquaero is not mounted in this picture, so I had to take that into considderation.
With the first few cables finished. As you saw in the previous pictures, I start out by making all the ends in one end, and then route the cables. I then cut the other end so it fits with the PSU, and the length the cables needs to be, crimp it, and put them into the connector.
And BOOM! A few hours later, the rest of the cables got connectors on the other ends as well. You have to be careful not to switch some of the wires this way as it is not super easy to see what wire is going where. But I have almost sleeved enough corsair power supply's by now to know the pin layout of the different ones in my sleep.
Really like this quad comb. The thing is a beast!
From the rear. Do not mind the zip ties, they are only in there to keep the different bunches of wires together for when I put connectors on them, and to keep the wires in the "route" I want them to go.
All the wires out of the build for testing with a PSU tester.
Proud to say that everything worked the first time around! So no magic smoke in this build!
I also managed to almost completely fill out the PSU with plugs! The only ones available now is the sata/moles plugs which is kinda scary!
Next up is piping!
On 4/4/2016 at 1:19 AM, p0Pe said:
It looks good, but will never be seen again.
Ek really has such nice refinement!
Next up is piping!
It makes me feel a little queasy to think how long this would have taken! and the patience involved... You say you've done a lot, though I think it would still be a job and a half to do this amount of cabling. I just finished doing my own RM650 and though that was a big deal haha. Nice job, as always. Very inspirational.
Better and better :)
How many gpu connectors are there on the back of ax1500i? 10?
