Help Choosing Monitor.
tucker1994
My Budget For A New Monitor Is Under 200 But I Found These 2 Monitors.
1.http://www.newegg.com/Product/Product.aspx?Item=N82E16824009642
2.http://www.newegg.com/Product/Product.aspx?Item=N82E16824014376&cm_re=benq_xl2411z-_-24-014-376-_-Product
Is it Worth Saving Up Just A Little More For the 2nd Monitor Or Will The First 1 Be Just As Fine?
I would go with the BenQ monitor. I don't like the glossy plastic used on the Acer.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
