Where do you obtain your electrical parts?
Guest
I'm very interested in learning electronics. I can solder, understand the basics and can identify resistors by memory. However I don't see many good options for getting parts. The nearest radioshack (which is probably expensive) is about an hour drive away. Amazon sells some form of most parts but they're also very expensive, and usually don't have prime. I see some parts that look pretty cheap on ebay and aliexpress but they would take quite a while (1-3 weeks) to get here. Where do you get your parts from? Any suggestions where I should try looking?
If I need anything like that I go to a place called Sayal Electronics. I live in southern Ontario though, dunno if they have any other locations.
Digikey is very popular.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
You mean the website or the actual store? The store is fairly far away.
Website.
3 minutes ago, DeadEyePsycho said:
Website.
Their prices seem pretty darn good. I'll look into it some more.
I go to Sayal too, I don't know if there have any locations out of Ontario. Also much of he stuff is overpriced and I have seen them seeling mastercraft, husky and other stores products. Even Raspberry pi's in Element 14 boxes.
For certain things even ebay is good, i bought rgb leds for example, they all work but you don't get datasheets whitch is really bad. But it works if you want to do something really cheaply. Things like resistors don't need datasheets and there are some mixed bag thing whitch go for pretty cheap as well.
Since my dad has an electronics service I get to salvage A BUTTLOAD of components.
Whenever we need components that are somewhat harder to get, we usually order straight from distributors if we need bulk. Single units we sometimes order from Texas Instruments directly (kinda expensive but we get our money back after servicing is done) or we just go get ripped off at the local electronics store.
If you can source broken tech you can easily salvage components off those (I have a huge box of assorted connectors, from HDMI, DP, VGA to audio jacks and SCART plugs). You could also take a look on Arduino-centric sites. Most of them also sell component "kits" that have pretty much everything you'll most commonly need, from resistors, transistors, capacitors to small motors, switches and plugs. Investing in a couple of those kits could save you a bit of a headache and they usually come in a nice sorting box.
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
Digikey and mouser are the place I use most frequently
I use Mouser.com as well as Digikey.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
Mouser is my main go to source.
Mostly I work on tube amplifiers and FX pedals, so after them it is Antique Electronics Supply and Small Bear electronics
