I need a Zero RPM Power Supply.
YT2002
Hey guys. I am putting together a PC that is intended to be very quiet, and I would like to know what is the best cheap PSU that has a Zero RPM mode in the US.
PC is Intel Core i5 6400, GIgabyte H170 Gaming 3, Corsair Vengeance LPX 2x4GB 2400Mhz ,Sandisk Ultra Plus 128GB, WD Blue 1TB, NZXT S340, ASUS Geforce GTX 960. Fractal Design Tesla R2 650W. http://au.pcpartpicker.com/p/793XNG. Graphics card choices don't always have to be dictated on performance. If you want the game stream and power consumption of the GTX 970 get that. If you want raw performance of the R9 390 get that. In the end we are all gamers, so what if your buddy gets an extra 5 fps?
what is the rest of the PC specs?
My CoolerMaster VSM550 is damn quiet
http://www.bit-tech.net/hardware/psus/2014/06/20/550w-650w-psu-roundup/6
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
pretty sure evga's GS and G2 series stop their fans when the load isnt big enough to create excessive heat.
just buy your psu VERY overkill. (my 4790k and gtx970 dont make the fan on my corsair rm750 spin up)
XFX XTR and Corsair RM PSU' s have hybrid fan modes that disable the PSU fan until a certain temperature is reached.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
if you can afford it wink wink
"God created war so that Americans would learn geography"
