144hz Monitor without G-sync vs 144hz Monitor with G-sync
My previous monitor was a Benq XL2411T which is a 1080p@144phz lightboost 2 monitor and currently I use a PG279Q which is 1440p@165hz gsync monitor.
Last year I also owned a PG278Q (1440p@144p) and had a lot of problems with repeated monitors and I ended up using my Benq a lot. So I have been using high refresh rate monitors for about 3 years now and gsync for a little over a year.
My experience tells me that gsync is kind of great, the image just feels solid and fluid and the frame rate matters a whole lot less. But playing BF4 at 100fps or so I don't notice a massive difference. There is definitely still a difference but where I really notice it is in the 30-60 range of fps where on a gsync monitor it remains smooth, its not good because its still a low frame rate but its consistent in a way you aren't used to without gsync being there. So if I was to sum up my thoughts I would tell you gsync just makes everything smoother, but >100hz will do that too but you'll be vsync off and that will impact on the image quality, you wont have that solid and lack of stutter feeling you get with gsync.
Personally I can live without gsync sort of, but I wouldn't want to. There is no way I am ever gaming at 60hz again but gsync I could live without, but I think its worth its asking price.
