HELP! Getting nasty GTA V problems after OC 770!
AlTech
So i OCed my 770 after I fixed the nasty thermal paste and re-applied good thermal compound.
I OCed it to 1200MHz (Up from 1100MHz) witH VRAM OCed to 7.2GHz (Up from 7GHz).
And after this GTA has been shitting the bed. I can't run the game for 5 minutes without GTA giving up and forcing the game to crash.
How do i fix this? This wasn't a bad overclock so what was it that caused this?
Thanks!
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
Obviously your OC is bad. Do this:
Stress test for 24hours.
If it fails, turn down the OC.
qst of all turn it back down and see if its the OC thats the issue or something else. if its stable well..not much you can do other then maybe try a lower OC. if anything id say the vram OC is causing your issues though since its fairly uncommon to OC vram
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
Have you tried reverting the OC back to stock speeds to see if the issue persists?
Yeah it doesn't have the problem since i switched back.
I'll try just OC core clock and leave memory clock.
I had the same issue, game crashing after I overclocked, the overclock was fine with every other game, as soon as I went back to stock speeds everything came right.
I have just been running it at stock ever since.
GPU: Gigabyte HD7970 | Mobo: ASUS Z97i PLUS | CPU: 4790K
HDD: Samsung 1tb SSD | Disp: 3x Asus 23.6" 1080p
RAM: 16gb Kingston Hyper X | Case: None
Thanks!
your overclock is too much. turn it down a bit and see.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
