Need help choosing stylus
Solved by Akiyo,
Just FYI - according to the spec sheets, your laptop uses a capacitive touch screen, so stylus that will work with the screen are limited to those capacitive stylus only, which really more mimics the tip of your finger than a pen,and more often that not its tip is a fat rubbery tip about the size of your pinky finger tip, you wont be getting the precision of a proper pen that have a special digitizer layer on the screen itself (Wacom, Samsung's S Pen).
But if you are just looking for something that will work, "Capacitive Stylus" is the type you are looking for, $3~$15 or so at most stores with digital product/online shop/amazon.
(It is incredibly pointless though.)
