Skylake build won't post! Boot device LED is on
Solved by Albie,
Try 1 stick of ram in every different slot, check your ram/ plugs are seated properly, run with only CPU, cooler ram and mobo. Try drive in another computer (don't boot from it, but rather connect it and see if you can accesses it etc.) If your PSU is modular try using a different connector for your drive.
Share
Followers
3
