Need help to choose mobo and graphic card for best performance
i just found out that there is one store that can give gigabyte product but the gtx980 g1 gaming but is 83$ more than the msi or asus one and it offers only 1 yr of warranty and 3 yr by asus and msi.
These mobo are also available
Gigabyte GA-Z97X-Soc Force LGA 1150 Intel Z97 HDMI Sata 6Gb/S USB 3.0 Atx Intel Motherboard Gigabyte GA-Z97X-Ud5H-Bk LGA 1150 Intel Z97 HDMI Sata 6Gb/S USB 3.0 Atx Intel Motherboard Gigabyte GA-Z97X-Gaming 7 LGA 1150 Intel Z97 HDMI Sata 6Gb/S USB 3.0 Atx Intel MotherboardThese are of same price i was looking for, so what should i do.
Should i stick with asus z97pro or go for any of these gigabyte ones and is it worth spending 83$ extra for the gigabyte 980 g1 gaming and get 2 yr less warranty too?
Mobo both Gigabyte and Asus are quite well known brand. So just choose the one that matches your need technically as well as in terms of color scheme if you have one. Basically in another words, more or less they are quite the same to some extend.
GPU if you are able to get hold of the gigabyte g1 980, get that. Heard it's very good in OC. But if you not going to OC the GPU, then get the cheaper 1 will do (which I assume here is the MSI gpu you mentioned).
