Need recommendation on 140mm case fan
benchan0310
I got my Fractal Design Arc Midi R2 and i want to replace the stock fans that come with the case for intake.
I have already done some research on 140mm case fan.
And I have found some fans.
Now I am choosing between Noctua NF-A14 FLX and Gelid Wing 14.
I prefer airflow over noise while not to be too noisy.
Any idea?
Or any other better choice?
Get the A14 FLX. If you are on a low budget THEN you get the Gelid Silent 14, not the wing.
You can consider the Be Quiet! Silent Wings 2 fans as well.
