Problems with my second monitor.
BatterySound
Different models. Black bars around the bigger one. The screens displaying the same thing but when I set it to extend one screen is impossible to access . Same resolution. One is using HDMI other is using VGA I think?  I'm not that knowledgeable about monitors so help me out here.
CPU: i5 4570 - GPU: R9 270 - Motherboard: MSI Z87 G41 - Case: Phanteks Enthoo Pro - PSU: EVGA 500W Bronze - RAM: Kingston FuryX 2x4 GB
Duplicate displays will match the resolution of the lower resolution display, thus the black bars. I don't understand what you mean by "extend is impossible to access"
Assuming your using Windows 7, it's pretty simple
http://www.ehow.com/how_8780838_enable-dual-monitors-vga-dvi.html
Just make sure both monitors are running at their native resolutions.
Mixing VGA and HDMI isn't a problem.
If you can, take screen shots of the settings for each monitor under the "Screen resolution" page  (Right click empty space on desktop)
Windows 7 has native support for dual displays, you can have a different resolution on each screen and an extended desktop.
I'm doing it right now.  An old 4:3 1600x1200 and 16:10 1920x1200 monitor, both running at their native resolutions.
A program like DisplayFusion will even allow you run dual task bars, wallpapers, screen savers and tons of other stuff.
I've never actually bothered with dual monitors, but I'm considering it with my new set-up and so that's very interesting information, jbr. Thanks.
it's impossible to duplicate different resolution displays and have each monitor running at its native resolution
Extended desktop
Which is why I asked him to post a screenshot, to see if he has "Extend these displays" selected
Extended desktop
I wasn't talking about extended desktop tho  :P
