Internet help and Is my speed okay?
eman21790
So Basically I have to use wifi because my mom won't let me bring the router/modem thing upstairs and won't let me run a cable through the entire house sooooo yea ( I'm a teenager). We pay for 12 mbps down and 1 mbsp up and almost get that 70% of the time (I get 10-11 down but never 12 and like .60 up). But about the other 30% of the time I get 1-3 mbps and .06 mbsp up???? This is usually at night. I've called. Tried reseting the router. Turning it on and off. But during this "down time" nothing works. If anyone can help me i'm all ears.
Rest in Pepperoni
It's probably just your isp being scumbags and not caring to fix their service. You can't do much about it other than call them an threaten to get a contract with another company if they don't fix it.
sudo chmod -R 000 /*
Does anyone else on the same network as you use the internet for streaming videos at night?
This isn't because you're on WiFi.
Compatible with Windows 95
Ah, well... we're paying for 100mbps and aren't getting the promised speeds either. We were 20mbps for a week after we ordered, than 25-26mbps, now we're around 32mbps, we don't know. Maybe they're "taking they're time." Most ISPs are just bad nowadays.
...Google Fiber, please come to Canada.
Build: CPU: Intel Core i5 4690k | CPU Cooler: Hyper 212 Evo | Motherboard: MSI Z97 Gaming 5 | RAM: 8GB G-Skill Ares 1600Mhz CL9 | Storage: 120GB Samsung 840 Evo + WD Blue 1TB 64MB Cache + Seagate Barracuda 2TB 64MB Cache | GPU: MSI GTX 960 | Case: Cooler Master Storm Enforcer | Power Supply: EVGA 600B Non-Modular |
Try changing channels of the router. May be interference
I Love Playing CS:GO!
Current
AMD Athlon X4 760K | MSI A78M-E45 | Sapphire R7 265 | Cougar Solution | Cooler Master Hyper T4 | ADATA XPg V1.0 1600Mhz 8GB | Fractal Design 650W
Do you have windstream because thats my exact speeds. No its not fine but unless your ISP cares ( Not Likely ) they aint going to do crap about it. Also it may just be upgrades, if this just happened call and report it to your ISP and ask if its a know problem and what it is. If they give a bull crap answer switch ISP's as soon as you can.
If they wont do anything ask for a monthly rebate until they fix it.
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
Yea im using windstream.
Rest in Pepperoni
At night i'd say we have 3 devices on the internet.
Rest in Pepperoni
Oops i meant to say 2
Rest in Pepperoni
You in Missouri if I may ask?
| F@H STATS |
Plus anyways our isp says that it should handle 4 devices streaming at the same time.
Rest in Pepperoni
No i'm in NC
Rest in Pepperoni
No i'm in NC
Oh, Well I know in Missouri they are upgrading their servers. Mine has improved a lot in the past few weeks. I would call and ask them if thats what they are doing.
| F@H STATS |
They said that there was a breach in the fiber causing our connection to be bad. But the guy came out and now it's doing the same thing.
Rest in Pepperoni
Have you tried stopping the second device and check the internet speed then? If the second device is using 11Mbps you obviously will only get <1Mbps on your machine.
Yeah I think it was just a bull answer. They will give you monthly rebates though of $30 a month so I would just ask about those. Call your local office and not Tech Support
| F@H STATS |
The second device is my sisters iphone and she can't go one second without it.
Rest in Pepperoni
She would only be on youtube at the most. Usually she is on youtube spotify that stuff.
Rest in Pepperoni
Is she doing anything network intensive on it? Like downloading stuff?
That is probably what makes your internet connection get so slow.
The same devices are on that where on before but now my speed 5 mbsp and .60 mbsp,
Rest in Pepperoni
Weird...
Usually it is that the bandwidth gets used up by another machine on your network...
Do you have any smart TVs connected to the internet?
If not then it might just be the area you live in, someone using bandwidth on the same ISP.
Weird...
Same devices and look now for yourself. http://www.speedtest.net/my-result/3565818067
Rest in Pepperoni
