Do these parts fit
AngelXX
yes it will, but what you should be saying rather then fit is do they work together? if you should be wondering if anything fits you should be wondering if the cooler you get will work with the ram
Specs
Connectivity wise they will fit like a charm but cooler clearance is an issue. Post your specs.
http://au.pcpartpicker.com/p/Lw6c4D I have the memory card & the video card already so i took them out of the list
