48 gb of ddr4 ram running at 2400 mhz or 32 gb running at 3200 mhz?
19 minutes ago, StyvyStiefel said:do I install the 32gbs and have it run at 3200mhz?
first of all, zen+ might not be able to do 3200MHz on 16gb dimms
maybe 3000 is a safer option
but if the prices arent too different then sure, you can manually downclock and tighten the timing if it doesnt run at 3200
as for your question,
16 minutes ago, Panoramix97 said:If you use more than 32gb of ram on ur pc usage then use the 48gb option
If you will never need the extra RAM, use the 32gb 3200 mhz option
answered it pretty well
because hitting pagefile sucks more than slow RAM
6 minutes ago, StyvyStiefel said:Is there an extra benefit to using the 3200mhz option over the 2400mhz?
some, though it may not be too obvious
mixing and matching RAM may not work though, so there's a possibility that it wont even boot with the 48gb config.
but it should be fine
