Search In
  • More options...
Find results that contain...
Find results in...
Rogerzz
Can I Control Non PWM Case Fans via a fan splitter?
Recommended Posts
Posted · Original PosterOP
I'm getting two Arctic P14s and would like to know If I will be able to control the speed of the fans using a separate fan splitter.
My motherboard has DC Voltage Control in BIOS.
Will it work?
Ryzen 5 3600 4.0GHz 1.1V | 16GB @ 3600MHz | GTX 1070 8GB | Corsair RMx 650W | Fractal Meshify C
Yes. The general rule with fan splitters is that the fans should all be the same control mechanism. If they're both voltage control, it works. If they're both PWM, it works. Where people run into trouble is mixing VC and PWM. But as long as they're the same control, and not so many of them that they overload the circuit (two is fine), the MB doesn't care how many of them there are. (Be aware, though, that they'll look like just one fan to your control software.)
