Search In
  • More options...
Find results that contain...
Find results in...
King Spartan
Help me pick a sound card?
If your motherboard is reasonably modern and a well built which it probably is. The difference in quality is so marginal its closer to no change.
Unless your planning on getting speakers to do a surround sound set up and you need more outputs for that.
OR
Your getting a fancy new microphone and want XLR inputs.
Those sound cards will be a waste of money.
Im sure you can think of something better to spend 100 quid on.
Recommended Posts
Posted · Original PosterOP
im looking to get a sound card my current pair of headphones are the Sennheiser HD 598SE. the 6 sound cards i am currently looking at are the
Audient EVO 4 USB Audio Interface
Creative Labs Sound BlasterX G6 Hi-Res Gaming DAC and USB Sound Card
Creative Labs Sound BlasterX AE-5 Plus - Black
EVGA NU Audio Card, Lifelike Audio, PCIe, RGB LED, Co-Engineered by EVGA and Audio Note
Creative Labs Sound Blaster X3 USB DAC
Astro Gaming - A40 TR Wired Stereo Gaming Headset for PS4, PC with MixAmp Pro TR Controller
if you think i dont need a sound card and or i need a new headphones please tell me.
i mainly watch shows movies and play games.
thanks any help.
if you like surround sound the sennheiser gsx 1000 is very nice for immersion in movies and games
topics i need help on:
my "oops i bought intel right before zen 3 releases" build
CPU: Ryzen 5 3600 (placeholder)
GPU: Gigabyte 980ti Xtreme (also placeholder), deshroud w/ generic 1200rpm 120mm fans x2, stock bios 130% power, no voltage offset: +70 core +400 mem
Memory: 2x16gb GSkill Trident Z RGB 3600C16, 14-15-30-288@1.45v
Motherboard: Asus ROG Strix X570-E Gaming
Cooler: Noctua NH-D15S w/ white chromax bling
OS Drive: Samsung PM981 1tb (OEM 970 Evo)
Storage Drive: XPG SX8200 Pro 2tb
Backup Storage: Seagate Barracuda Compute 4TB
PSU: Seasonic Prime Ultra Titanium 750W w/ black/white Cablemod extensions
Case: Fractal Design Meshify C Dark (to be replaced with a good case shortly)
basically everything was bought used off of reddit or here, only new component was the case. absolutely nutty deals for some of these parts, ill have to tally it all up once it's "done" :D
Overpriced... Get the G6 instead.
PM or DM me if you have any questions about audio or about your PC.
My pc specs
CPU > Intel core i7 9700k, GPU > RTX 2070 8gb, RAM > Corsair Vengance 2x8gb 3000mhz, Motherboard > Z390 Gigabyte Aorus Pro Wifi, Storage > 1TB HDD & 500gb M2 SSD, Cooling > H100I Corsair Platinum, PSU > Corsair RM750X V2
🎧Current Audio Setup For Gaming🎧
DT 990 pro 250ohm W/Straight cable and Dekoni Elite Velour Pads
Soundblaster AE-9 Soundcard
The T.bone SC400 XLR mic
Other peripherals
Keyboard > Razer Chroma v2 Orange Switches
Mouse > Logitech G502 Hero
Read this post if you want a "gaming" headset ;)
thanks any help.
I would say the AE-5 plus since it has more amp power. But maybe the G6 suits you better? Depends if you want more portability.
My pc specs
Other peripherals
perhaps but its got much nicer surround. got mine for 130 which wasnt too overpriced at all
Posted · Best Answer
OR
Here to educated the audio board on their bad choices.
OR
thanks for the help
