my audio system does not sound good
popeyeindian
Hello Forum,
I have recently bought Klipsch RP600M speakers along with Denon DRA 800 H amplifier. I use Tidal (Hi-Fi/MQ) to stream the music on it.
but it does not sound good. what can I do to improve sound quality? does adding a pre-amp help? is the source good enough (I am running Tidal on my phone though I think the receiver streams it directly without involving the phone)
Thanks,
What do you mean it "does not sound good"? What doesn't sound good to your ears? You can try and EQ a bit, however if you are used to cheap logitech speakers it is quite a difference once you start moving up in the audio world. If that's the case, remove your expectations of "what i had before, but better", and try to listen to songs and look for nuances in the songs that you maybe never knew existed.
I don't have experience with those speakers though, my friend has some of the floor-standing ones in his living room.
Quick check: are your speakers in phase? Make sure the polarities out from your amp match to the inputs of your speakers.
Otherwise, describe the qualities you feel you're missing?
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | Mellanox ConnectX-3 10G NIC | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
Proxmox Server (Veda): Ryzen 7 3800XT | AsRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4x 10TB WD Whites / 4x 14TB Seagate Exos / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X540-T2 10G NIC | LSI 9207-8i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives) | VMs: TrueNAS Scale; Ubuntu Server (PiHole/PiVPN/NGINX?); Windows 10 Pro; Ubuntu Server (Apache/MySQL)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / Seagate 1.5TB HDD | Corsair CX450M | Viewcast Osprey 260e Video Capture | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
                           ┌─────────────── Office/Rack ────────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch 8-60W ─┬─ UniFi Switch Flex XG ═╦═ Veda (Proxmox Virtual Switch)
(500Mbps↑/500Mbps↓)                             UniFi CloudKey Gen2 (PoE) ─┴─ Veda (IPMI)           ╠═ Veda-NAS (HW Passthrough NIC)
╔═══════════════════════════════════════════════════════════════════════════════════════════════════╩═ Narrative (Asus USB 2.5G NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ──────────────────────────────────────────────────────┐
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═╦═ Byarlant
   (PoE)                 │                        ╠═ Narrative (Cable Matters USB-PD 2.5G Ethernet Dongle)
                         │                        ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Sony XR65A80K (Google TV)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Samsung 850EVO 250GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M | HooToo USB 3.0 PCIe Card | Osprey 230 Video Capture | NZXT H230 Case
TrueNAS Server (La Vie en Rose): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 1x Kingston 16GB SSD / Crucial MX500 500GB
I had a bose system before (still do) and these Klipsch speakers sound a bit harsh to me(they definitly sound better than bose though), a bit more treble than I would like.
Also, I have experimented with EQ. dont make assumptions about what speakers I or anybody else is used to .
Nobody's assuming anything :) He's just mentioning there's a big difference between common "cheap" speakers and actual high end audio speakers. For all we know your "Bose system" (name doesn't always mean quality) sounds terrible.
Klipsch are known to be bright (or harsh as you say) on the treble. You can try EQing the treble down, but in the end some speakers will have a certain sound to them. That's why people often recommend to listen to them if you can before buying.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
how do I check for phase? they are connected with a 16 Gauge cable to the 'B' terminal on the amplifier.
it has more treble than I would like and EQ does not make it go away. I think a pre-amp might help but not sure. it sounds distorted when playing some tracks but sound okay for others.
Thanks for your reply. :)
I was throwing those speakers out as a general example of what most people start off with. (Myself included). I was in the same boat where once I got some decent speakers the difference was night and day, at first I had negative thoughts about the "lack of fat bass etc" and the treble also seemed to stick out far too much. My ears were just accustomed to bass heavy audio with the highs severely cut off. Watching LTT and other youtube videos, movies, music.. all sounded so much different from what I was used to.
Now that I've had time to adjust to a flatter frequency response, logitechs are now the odd-sounding speakers to me.
If all you have are sharp highs, and tried EQ... I'm not too sure what else to say except you could possibly return those speakers if qualified for refund and try other speakers.
I see... sorry about that.
I am hoping a pre-amp would fix the issue.
You can try and "mask" the highs with a pre-amp however as @tikker stated above, speakers have their own unique characteristics to them. Either trying before buying or going to shops and listening is your best bet. Next in line is to do as much research as you can.
Now that you know how those sound, you can try to find some graphs and reviews of what people say about them and look for other speakers with a little less treble.
Just make sure red terminal goes to red terminal, black goes to black. I messed this up once and spent a week wondering why my speakers suddenly sounded so different (it causes soundwaves to cancel themselves out).
Network:
                         │                        ╚═ Jesta Cannon*
Retired/Other:
If it was out of phase I don’t think you’d be experiencing the harshness in the way you describe - both more and speakers are bright and it sound like it’s not a sound trait you like.
you need to change your speakers for something ‘warmer’ - is that an option and what would the budget be please?
  • 2 months later...
I added a SMSL M400 DAC, started using a desktop PC to play music and got high resolution audio files for the music I want. Also, added a Dayton Audio Sub.
The system sounds great now 😀
Thank you all for replying.
Try taking a half or quarter of a cotton ball and stuffing it in the tweeter hole.  It's an easily reversible mod if it sounds terrible.
Also experiment with position and angling. Try them further away and try a toe-out angle.
