Breakout cable for Fan RGB
Solved by thrasher_565,
2 hours ago, TonytheEE said:Unless of course the TT fans data simply doesn't work with whatever serial format the ARGB hookup on the ASRock Mobo uses. I'll at least test putting the connectors on the ARGB (foregoing one fan at a time. That lil Ryzen 3 won't mind) to make sure that they will at least light up on the ARGB Header.
i hared that asrock may have different pwm duty cycals on there argb but it could have been only serten chip sets or was old mb. only way to tell is to test it. it might work or might not work or flicker. well i wish you luck
