First Build Ever - General Advice, CPU Cooler and Storage Options
Solved by SupaKomputa,
3600xt came with a wraith spire. Which is good enough for day to day operation.
Just test it first before getting aftermarket one.
3600xt may not be a good overclocker as the clock already pushed to the edge by amd.
Thats why everybody here recommending 3600 instead as the oc headroom is still higher and probably can match 3600xt performance.
