HOW to mod xbox 360 wireless to wired usb for PC?
dfsgsfa
i connected at the back pcb a usb cable to usb, pc seems to detect something
but no further progress, any idea?
I don't get what are you trying to do use the 360 wireless adapter on pc?
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
just use the charging cable that comes with the controller, (if this is a battery controller it won't have this) and plug it into the pc and BOOM it works
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
