System build i need help and suggestions with.
Just now, StrawberryShortCakes said:Paying by credit card covered by his company but he said not to go crazy
i see few changes i might do:
8 minutes ago, StrawberryShortCakes said:Ryzen R5 3600 - (should I go for a higher core cpu?)
this should work, but going for a 3700x should help if the person is doing multithreaded workloads also add a cooler like a scythe ninja 5 (great cooler and doesnt run at high rpms)
9 minutes ago, StrawberryShortCakes said:Asus TUF Gaming B550M Plus WiFi (no rgb as requested)
you can also opt for the B550 A-Pro, iirc the TUF still has RGB
10 minutes ago, StrawberryShortCakes said:Samsung 970 Evo 1tb m.2 nvme or Crucial MX500 1th m.2 ssd (should I go nvme or sata?)
if the person needs faster speeds, NVME wont hurt, any prices on the SX8200pro, EX950, Rocket, P34A80?
11 minutes ago, StrawberryShortCakes said:Gpu - I can't find any gpu without rgb unless I go for quadro but it's too noisy - (Blower fans)
Does the person need Cuda? if not then maybe go for a XFX Thicc III 5700xt
14 minutes ago, StrawberryShortCakes said:Fractal Design ion+ 760w 80+ platinum full modular (Silent running)
rather overkill, the 660 watt version should be more than enough
