How much watts do I need for UPS for my PC?
Steel Zen
PC SPECS LIST
Motherboard: X570 AORUS MASTER
CPU: Ryzen 5 3600
CPU Cooler: CORSAIR H100i RGB PLATINUM
RAM: AORUS RGB MEMORY 16GB (2x8GB) 3600MHZ
GPU: Asus ROG STRIX GAMING GEFORCE RTX 2070 OC EDITION 8 GDDR6 Memory
SSD: SAMSUNG V-NAND SSD 970 EVO PLUS NVMe M.2 ~ 500 GB
         SAMSUNG V-NAND SSD 860 EVO SATA 6GB/s ~ 1TB
HDD: WD Black 4TB
PSU: CORSAIR RM650
Case: COOLER MASTER H500
Put this on part picker and you will see the wattage. Then user a PSU 1.5X that wattage. Just choose a known brand. That happens because a PSU is loosing a little bit of it's capabilities over the years, so better be safe than sorry. Also they work better under their 80%
You will see about 400watts (I guess) so a 600w is all you will need
A UPS is not the same as a PSU.
Also, they don't "lose capabilities" the only thing that can possibly happen is battery capacity depletion, but that has nothing to do with the wattage output from the unit, that only affects the runtime.
yeah UPS is more like a power backup for the pc basically
38 minutes ago, Steel Zen said:
-snip-
Honestly a 450W UPS would do fine, even if the power goes out you'll have a good 20min at least. Cyperpower makes a good UPS, I have a 900W and 450W unit from them.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
what about the brand APC?
and also do you think an APC 650VA 325 Watts UPS is enough bcuz there's one of this APC  that no one uses in my house and its around 4 years old.
1 hour ago, BlueScope819 said:
At least 10. Quite possibly even 20.
Go for at least 600 watts
I think you mistaken it for PSU man but I'm actually asking for UPS not PSU both of them are different.
UPS is the power backup and PSU is the main source of power that power everything inside the pc
Yeah APC is good, and 325W is enough, I mean the MAX draw of your system is only around 300-350W and that is never sustained for long periods. You would have enough time to shut the system off if the power went out (audible warning).
My Builds:
MEGA Desk Build
But will it last until 10 mins atleast?
Bcuz the dangerous part is when I have to update the bios and stuff like that
Also I wanna get one that can last for atleast 1 hour or 30mins or so
At idle or load?
Most UPSes only last a few minutes at full load, you would need a really large one if you want to go for hours and that would cost several thousand dollars.
I would recommend a Cyberpower PFC LCD unit, those are pure sinewave.
I have a 1500PFCLCD.
Yes it probably would, these are highly unlikely scenarios to begin with I wouldn't worry that much.
My Builds:
MEGA Desk Build
That board has dual bios and q-flash, I think you're quite safe even without a ups :D
I see...
thanks for your help PC MASTER RACERS!!
I appreciate it :D
But the thing is Idk how to use dual bios and q-flash😅.I guess I have to watch Linus' video if he makes one idk whether he already makes a video about it or not or I just have to watch it from other random tech youtubers on how to do it
On 7/23/2020 at 12:13 AM, Enderman said:
At idle or load?
At load, wow damn thousand of dollars uh
If your PC uses like 500W at load and you want it to last an hour then you need at least 500Wh of energy storage, which is like five 12V 9Ah batteries, not including all the conversion losses..
Some rackmount UPSes have four, my Cyberpower UPS only has two.
For example, this one has four batteries:
https://www.cyberpowersystems.com/product/ups/pfc-sinewave/or2200pfcrt2u/
It says at half load (1100W is half of 2200) it can last 15 mins, so with your ~500W PC it could do half an hour.
It costs $500 USD, but if you want to get an hour of runtime you will need a different model, one with external battery connection so that you can attach a secondary battery unit with another 4 batteries or whatever.
Nah I don't think I'm gonna buy that UPS because it's too costly for me.Back at my place it'll cost RM2000+ but thanks for the recommendation anyway 😀👍
